magneto Posted October 12, 2011 Share Posted October 12, 2011 (edited) Basically changing the size of the dots representing the vertices when you edit geometry. Is there a way to change this? Also when I am using ops like PolySplit, the red cross and the circle that appears over edges are very small. Is there a way to make these bigger? Lastly where can I change the color of the non-selected vertices when editing geometry? Thanks in advance 8) Edited October 12, 2011 by magneto 1 Quote Link to comment Share on other sites More sharing options...
dangerweenie Posted October 15, 2011 Share Posted October 15, 2011 Yeah, I'd like to know this too. In Maya , just tapping "+" or "-" changes the currently used manipulator. It's good for when you're changing scale. The vertex display size, I'm not so sure about, but I'm pretty sure it's available too. Any way to do this in Houdini? Best, Matt Basically changing the size of the dots representing the vertices when you edit geometry. Is there a way to change this? Also when I am using ops like PolySplit, the red cross and the circle that appears over edges are very small. Is there a way to make these bigger? Lastly where can I change the color of the non-selected vertices when editing geometry? Thanks in advance 8) Quote Link to comment Share on other sites More sharing options...
guache Posted October 16, 2011 Share Posted October 16, 2011 Basically changing the size of the dots representing the vertices when you edit geometry I don't know of a direct way, but as a workaround, you can attach a Particle SOP to your geometry to get particles at each point, then in the viewport's display properties, under Particles, set the size of the squares representing the points. Quote Link to comment Share on other sites More sharing options...
