anupamd Posted October 13, 2011 Share Posted October 13, 2011 This one's got me really stumped. I have a shell generated by the voronifracture sop. I'd like to delete the inside faces so I have a nice shell on the outside. I know that the SOP createse inside/outside groups but lets assume that group does not exist, how can I isolate the inside faces and delete them so that I have a nice shell on the outside? I've tried just about everything. 1. Scattering points then using he ray sop to project the points onto the surface, then attribute transfer to isolate only the outside faces. because the attribute transfer works with sort of a metaball radius the result is very inaccurate. 2. I've tried using the divide sop with remove shared edges. That does not work. 3. I can isolate the top and bottom surface, but I still have an issue with the sides. 4. Perhaps simply doing a fuse, and then deleting coplanar faces will do the trick. But I dont see a way to delete coplanar faces. Quote Link to comment Share on other sites More sharing options...
anupamd Posted October 13, 2011 Author Share Posted October 13, 2011 see attached Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted October 13, 2011 Share Posted October 13, 2011 Hi. here is a simple solution. delete_interior.hip Quote Link to comment Share on other sites More sharing options...
anupamd Posted October 13, 2011 Author Share Posted October 13, 2011 Thanks for the reply, your solution works but unfortunately it relies on the inside group and outside group actually being intact. I don't have that luxury because the outside group is not correct in my example. See the attached hip. But yea I wish it was that simple One way is to fuse everything and then delete co-planar polys, but Houdini has no such handy node and Im trying to avoid writing some python, but I might have to. Hi. here is a simple solution. delete_interior.hip cleanvoroni.hip Quote Link to comment Share on other sites More sharing options...
edward Posted October 14, 2011 Share Posted October 14, 2011 Yeah, this would make a good odforce challenge to do this properly without python. The problem is that SOPs needs some more tools to deal with polygons and such. Doing it in python shouldn't be too hard provided you have fused all your points first. Then the solution in python I think would go something like this: - for each primitive, build a sorted list of its vertex point numbers - now do a nested loop which compares each primitive against every other primitve - if two primitives have identical vertex lists, then mark both of them for deletion Quote Link to comment Share on other sites More sharing options...
zarti Posted October 17, 2011 Share Posted October 17, 2011 This one's got me really stumped. I have a shell generated by the voronifracture sop. I'd like to delete the inside faces so I have a nice shell on the outside. I know that the SOP createse inside/outside groups but lets assume that group does not exist, how can I isolate the inside faces and delete them so that I have a nice shell on the outside? I've tried just about everything. .. this seems to work ( without python ) .. cleanvoroniz.hipnc 1 Quote Link to comment Share on other sites More sharing options...
