Achayan Posted October 18, 2011 Share Posted October 18, 2011 Hi All, Is there any way I can promote a parameter from vopnode with python ?. I was trying some other solution like find the parm type and all those stuff but nothing come good . And I didnt find any really helpful doc from houdini also maybe I didnt do a good search . So if any one has a idea how I can promote a parameter then it will be really helpful. So here is workflow Create a Material Shader builder and go inside the vopnode then create a colormix then middle click on any parm then promote as parameter . I want the same promote as parameter flow with python or hscript . Thanks Quote Link to comment Share on other sites More sharing options...
Achayan Posted October 19, 2011 Author Share Posted October 19, 2011 Any clue guys ? Quote Link to comment Share on other sites More sharing options...
edward Posted October 20, 2011 Share Posted October 20, 2011 Use python code to create a parameter vop, wiring it up as appropriate. Quote Link to comment Share on other sites More sharing options...
Achayan Posted October 20, 2011 Author Share Posted October 20, 2011 Yes thats possible but the issue is the source parm never say the correct parm type , say for ex if its color then it will say float in one way its right , and for the order menu and a int both it will say int . so its really confusing and i didnt find any way to get the type properly otherwise I need to use look and name scheme to find it . Quote Link to comment Share on other sites More sharing options...
goldleaf Posted April 15, 2015 Share Posted April 15, 2015 In case someone else comes across this thread, trying to promote VOP Parms with Python (i.e. HOM code that does the same as RMB > Create Input Parameters), it's insertParmGeneratorsForAllInputs(). Here's an example, on a Color Mix VOP: hou.node("/obj/geo1/primitivevop1/colormix1").insertParmGeneratorsForAllInputs(hou.vopParmGenType.Parameter,True) Hope it's helpful! 2 Quote Link to comment Share on other sites More sharing options...
