eirik.m Posted November 1, 2011 Share Posted November 1, 2011 Hello I have a piece of geometry which is pre-fractured using voronoifracture node inside a SOP net. This SOP net is brought into my simulation. But when my collision object collides, my fractured object it appear as two different objects. One as a fractured piece and the other is still a whole piece. It also seems that they behave different in terms of collision and forces. Inside the voronoifracture i have checked on the "create inside Surface" and "connect inside Edges". I have also followed the recipe in the Houdini floating help under "How to auto fracture geometry". Does anyone have a clue on what might be wrong here ? Thank you very much - Eirik Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted November 1, 2011 Share Posted November 1, 2011 What groups do you import into DOPs? Voronoi fracture creates both piece*, inside and outside. Brining in both the pieces and the inside,outside info would probably produces something like what you are getting. Quote Link to comment Share on other sites More sharing options...
eirik.m Posted November 1, 2011 Author Share Posted November 1, 2011 Ok, I had all of the output groups selected. I tried deselecting the Piece group but it did not help. I will try now with the different groups now. Thank you Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted November 1, 2011 Share Posted November 1, 2011 You wan't to import something along the lines of piece* to get a working simulation. Quote Link to comment Share on other sites More sharing options...
eirik.m Posted November 2, 2011 Author Share Posted November 2, 2011 It worked very well, thank you Quote Link to comment Share on other sites More sharing options...
