jim c Posted November 12, 2011 Share Posted November 12, 2011 In Vue there's an option to render out the scene as spherical 180 degree view, something that can then be used as an HDR image. Is this possible in Houdini? I know there's a way to bake out a texture given some geometry and a UV map, but is there a way to get the scene it self onto the texture map? Any suggestions? Quote Link to comment Share on other sites More sharing options...
phs Posted November 12, 2011 Share Posted November 12, 2011 (edited) http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=101342&sid=1af26091005e6a1c05d447cd2767f6d2 http://www.sidefx.com/docs/houdini11.0/rendering/cubicenvmap http://www.sidefx.com/docs/houdini11.1/ref/utils/isixpack hope that helps. Edited November 12, 2011 by phs Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted November 12, 2011 Share Posted November 12, 2011 I don't think you can render out a spherical environment map but you can render out a cubic map. The process is described in the docs. http://www.sidefx.com/docs/houdini11.1/rendering/cubicenvmap Just using isixpack is a pain as you need to setup all cameras by yourself to create the images it needs. Quote Link to comment Share on other sites More sharing options...
jim c Posted November 13, 2011 Author Share Posted November 13, 2011 OK thanks guys. Erik_JE, in the thread that phs linked to, I think the first link, someone mentions spherical projection, or at least that's kind of what I understood. I'll look into this. Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted November 13, 2011 Share Posted November 13, 2011 That's nice. Even easier than the cubic method. Quote Link to comment Share on other sites More sharing options...
