magneto Posted November 16, 2011 Share Posted November 16, 2011 Hi, I am creating several attributes and connecting each other one after the other but at the end when I connect it to my Point OP, I can't access all the attributes that I created. Do these OPs not append another attribute after the previous OPs? I assume that's the case. If so, how can I merge all of them so I can use them in my Point OP? Thanks. Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted November 16, 2011 Share Posted November 16, 2011 you should be able to use all of your attributes in your point sop, ( if you're connecting them correctly) btw, you can always check which attribute is passing through by middle clicking on your nodes. Quote Link to comment Share on other sites More sharing options...
3dbeing Posted November 16, 2011 Share Posted November 16, 2011 I've often found confusion with vecotrs as there are 2 kinds, so be sure you are appending the correct component type ie. $ATTRX, or $ATTR0, or $ATTR1. You can always pop open a details menu to see the explicit atribute names. Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted November 16, 2011 Share Posted November 16, 2011 (edited) I've often found confusion with vecotrs as there are 2 kinds, so be sure you are appending the correct component type ie. $ATTRX, or $ATTR0, or $ATTR1. You can always pop open a details menu to see the explicit atribute names. $ATTR0 is the first component of a 3 float attribute, but $ATTRX is the first component of a Vector. Edited November 16, 2011 by ehsan parizi Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 16, 2011 Share Posted November 16, 2011 I am creating several attributes and connecting each other one after the other but at the end when I connect it to my Point OP, I can't access all the attributes that I created. Do these OPs not append another attribute after the previous OPs? I assume that's the case. If so, how can I merge all of them so I can use them in my Point OP? There are two things to do in these cases, which will allow you to at least know if your attributes are being created the way you expected them to be. First, on any node in the network click the middle mouse button. A popup window with a black background will appear, and in this window is will list of custom attributes that have been created (and other details). Attributes will be shown in the SOP, POP, DOP and CHOP networks. So it's important to learn what everything in this window means. At first, it'll seem like all Greek. Second, there is a window in Houdini called "Details View" which lists all the attributes for the currently selected node. This window shows details for all the different networks, and is very handy. To open the window click the "+" plus icon between the tabs in a window panel. "Details View" is listed as a possible panel type. When the window is open you can change which type of attributes to view from buttons on the upper/right of the window. Using these tools, click each node in your network and see if the attributes are being created the way you expected them to be. If you middle click the Point SOP you should see the attributes previously created by the CreateAttribute SOPs. Quote Link to comment Share on other sites More sharing options...
magneto Posted November 16, 2011 Author Share Posted November 16, 2011 Thanks guys, it works now. I didn't realize the "name" (attibute1) of the attributes were all the same. I thought I only needed to change the "local name". There are two things to do in these cases, which will allow you to at least know if your attributes are being created the way you expected them to be. First, on any node in the network click the middle mouse button. A popup window with a black background will appear, and in this window is will list of custom attributes that have been created (and other details). Attributes will be shown in the SOP, POP, DOP and CHOP networks. So it's important to learn what everything in this window means. At first, it'll seem like all Greek. Second, there is a window in Houdini called "Details View" which lists all the attributes for the currently selected node. This window shows details for all the different networks, and is very handy. To open the window click the "+" plus icon between the tabs in a window panel. "Details View" is listed as a possible panel type. When the window is open you can change which type of attributes to view from buttons on the upper/right of the window. Using these tools, click each node in your network and see if the attributes are being created the way you expected them to be. If you middle click the Point SOP you should see the attributes previously created by the CreateAttribute SOPs. Thanks I was using the middle click but not when this was happening I think. After the issue is fixed though, even though I added 3 attribs, it showed another one listed with something called like "varmap". Do you know what this is? Is the Details View the same thing as right clicking an OP and clicking "Spreadsheet"? Thanks again guys Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted November 16, 2011 Share Posted November 16, 2011 (edited) Is the Details View the same thing as right clicking an OP and clicking "Spreadsheet"? yes! Edited November 16, 2011 by ehsan parizi Quote Link to comment Share on other sites More sharing options...
magneto Posted November 16, 2011 Author Share Posted November 16, 2011 yes! Thanks Ehsan Quote Link to comment Share on other sites More sharing options...
3dbeing Posted November 16, 2011 Share Posted November 16, 2011 (edited) $ATTR0 is the first component of a 3 float attribute, but $ATTRX is the first component of a Vector. Ok esshan, and what is the differnece beween 3 floats and a vector? (edit) also, there are special cases, i forget exactly off hand where; but there are times when $ATTR1 is actually the first component in a 3 float. sometimes 1, sometimes 0, sometimes X. That was the point i was making. Edited November 16, 2011 by 3dbeing Quote Link to comment Share on other sites More sharing options...
magneto Posted November 17, 2011 Author Share Posted November 17, 2011 Ok esshan, and what is the differnece beween 3 floats and a vector? (edit) also, there are special cases, i forget exactly off hand where; but there are times when $ATTR1 is actually the first component in a 3 float. sometimes 1, sometimes 0, sometimes X. That was the point i was making. Symek told me that floats are faster than vectors so I assume floats are arrays, and vectors are structs. Quote Link to comment Share on other sites More sharing options...
3dbeing Posted November 17, 2011 Share Posted November 17, 2011 Symek told me that floats are faster than vectors so I assume floats are arrays, and vectors are structs. I fail to see any fundemental difference, yes data type is different but why should a construct be slower than an array? If this is true, and I'm not saying it's not; then why ever use a vector? Perhaps this why vops default output is 3 floats rather than a vector? Quote Link to comment Share on other sites More sharing options...
magneto Posted November 17, 2011 Author Share Posted November 17, 2011 (edited) I fail to see any fundemental difference, yes data type is different but why should a construct be slower than an array? If this is true, and I'm not saying it's not; then why ever use a vector? Perhaps this why vops default output is 3 floats rather than a vector? I think vector would be useful if you want to do transformations using the built in methods, matrices as Symek mentioned. I don't know about vops much yet, but if it's SIMD, arrays should provide better performance. I am not an expert on optimizations but arrays are pretty light-weight in general, compared to other complex data types like structs, classes, etc. Edited November 17, 2011 by magneto Quote Link to comment Share on other sites More sharing options...
