How to change the category of all my DAs?
magneto
It's stored in the 'Tools.shelf' section of your asset definition.
You might want to unlock the asset, grab the contents of this section, make your changes, put them back and lock it.
node = hou.node( [your node] )
definition = node.type().definition()
print definition.sections()['Tools.shelf'].contents()
You also might want to spend some time with the documentation of the hou module.
Thanks guys. I had to add it to my scene and then modify the instance with the edit operator type parameters dialog, and resave.
By category I meant the one that's normally called "Digital Assets" when you bring the tab menu. I wanted my DAs to be in another category.
Thanks rdg, I will try your method next time. Although I was looking for a user solution without coding. I thought Houdini would have some dialog for this.
