Is it possible to do generator SOPs using Python?
magneto
Of course. You can create points and various types of primitives and use them to create larger things such as a teapot.
Thanks Graham. For this do I not use the File > New Operator > Python?
I just start from a blank script and create a geometry and so on?
All have done so far was what is handed to me from up the stack.
Sounds like you might be interested in the Script SOP. It lets you run a Python script during the cooking process.
I'm not sure, but you might be able to reference a Python script inside an asset using the opdef:/ reference.
Thanks hopbin. How do you create one? I assume script SOP is hscript SOP then?
