how to keep the smoke continuously?
acti
Yeah taking a look at it, i think what you want is the pop-solver. I dont have time to do it right now, but see if you can look into it and sort it out using a popsolver rather than sopgeo...
ps prolly a better idea to put the popnet in the dopnet rather than outside...
Edited by 3dbeing
Actually to get the subframes you just need to append a timeblend sop to your cached particles, and set the frame range, it will create the inbetween frames for you and that should fix your issue.
There is no need here to use trail or do complex stuff in dops.
Great info Div! How long has this node been around?! LOL..
Stretch/Blur your source. Sub-stepping is pretty expensive. By blur, I mean trail your source so that the tail covers just over the region of the gap (and the tail perhaps contributes less fuel). Gets rid of gaps with no extra processing costs.
Edited by aghourab
