near point and next
hello,
I want to know if there are a faster or better way do this stuff : define a start point then find the nearpoint in a pointcloud then join them together and next repeat the same stuff with le last point a "x" number of time.
For the moment I use a foreach loop with group and degroup system. With that system there are two problems : speed with hight number of iteration, and if the number of repeat or "the treshold raduis"(see in the hip file) are too high the foreach node "break".
Thank you,
Thomas
Uhmmm, here is an untested idea:
In a sop solver: Make a point P and a pointcloud PC. Find the nearest point in PC to P. Move P along the vector to that point. Delete the visited point. Repeat. Then draw a trail from this.
Another way is with Python. I've tried this before and it can be very fast indeed if you use the right libraries (can't remember which one but it was related to graphs)
Edited by Macha
