Fabiano Berlim Posted December 14, 2011 Share Posted December 14, 2011 Is there a way to resample a line based on an attribute? The resample sop node only accept the $T variable. Am I missing something? In the end I want to resample based on the parametric value of the curve. Is there any other way to do it? Quote Link to comment Share on other sites More sharing options...
Macha Posted December 14, 2011 Share Posted December 14, 2011 You could resample like crazy and then delete by attribute. Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted December 14, 2011 Author Share Posted December 14, 2011 That's a good idea! In the end I solved using the curve as "Path Object" for a point that emit particles. With the right speed of the point I was able to reconstruct the curve with the amount of samples that I needed. Thanks for the idea! Cheers! Quote Link to comment Share on other sites More sharing options...
symek Posted December 15, 2011 Share Posted December 15, 2011 You could try chops' LookUp. It's a nice way to control samples density by hand or attribute. See example. cheers, ps btw, Macha, perhaps it would be a tip for your recent question about probability density functions too. Unfortunately I hadn't time to dig into it. resample_chop.hip 2 Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted December 15, 2011 Author Share Posted December 15, 2011 You could try chops' LookUp. It's a nice way to control samples density by hand or attribute. See example. Amazing example! Thanks a lot SYmek! Quote Link to comment Share on other sites More sharing options...
