Liquid Simulations
JuriBryan
hey i am trying to set up a liquid simulation that is driven by an existing particle system..
but i can't manage to get that working.
do you guys have any tips for me?
Oh and there is also a problem with the collision in my file...
my particles only slide a bit on the surface instead of moving for ever even with no friction turned on...
cheers..
btw the forum is amazing and you guys helped me a lot with DOPs already, so thanks;P
LiqiudSimulationTest.hipnc
cheers..
when you say "drive" do you mean transfer velocities or emiting fluid or both...
I want to get the velocity from my particle system to my liquid simulation...
i managed to get a decent effect with the velocity node in a fluid object but i don't get the extra details in the velocity that i would get with a particle sim..
here is the hip file for that, but there is a big problem with it... when i run the simulation the fluid simply sticks on the side of the sphere and is not running down...
cheers
FluidSim.hipnc
anyone got a idea what is going wrong there?
What is it that velocity impulse is doing?
Velocity Impulse Force
Impulse is force * time and thus corresponds to a change in momentum... An object will receive force corresponding to the impulse divided by the timestep, thereby causing the object to gain the specified momentum in a single simulation step.
Also if you notice on the noise dop, the output is green, this indicates it be plugged into a green input.
Finally you have your force set to set initial, prolly you want it set to set always then animate it's values. have a look
Edited by 3dbeing
