pyro scattering pc files
cloudfx
it keeps writing everytime I render and I cant find turn off re-generate from the pyro shader.
On the pyro shader on the settings tab, you find the shading mode. This needs to be set to normal shading. The rops created for the pc generation are running scripts that are setting the mode to actually write the pc files.
