Tom Posted January 13, 2012 Share Posted January 13, 2012 (edited) Here is example of what I wan to achieve: http://vimeo.com/34501279 I made this while ago, but the problem is that every next line with delay is created by "hand", manualy copying them. I would like to make this procedural, but I ran into small problem. Scene file is attached with more in-depth description. Thanks in advance! odforce_music_anim_v1.hipnc Edited January 13, 2012 by Tom Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted January 13, 2012 Share Posted January 13, 2012 I'm thinking a Copy SOP with a Subnet that contains the CHOP. You can then use copy/stamp to adjust the delay with each copy. Quote Link to comment Share on other sites More sharing options...
Tom Posted January 13, 2012 Author Share Posted January 13, 2012 I'm thinking a Copy SOP with a Subnet that contains the CHOP. You can then use copy/stamp to adjust the delay with each copy. Thanks for reply. I had very similar idea, but I just wanted to know if its possible to increase delay automaticly. Lets say I want to create box grid with resolution 100 x 100, that would be annoying doing that for all 100 subnets. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted January 13, 2012 Share Posted January 13, 2012 I don't know if the Copy SOP approach would be effective. It could take a very long time to cook a network like that. Quote Link to comment Share on other sites More sharing options...
Tom Posted January 13, 2012 Author Share Posted January 13, 2012 I don't know if the Copy SOP approach would be effective. It could take a very long time to cook a network like that. What expression in stamp value I need to use to delay it by each copy? Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted January 13, 2012 Share Posted January 13, 2012 I'll give this a try and post a file, but not until later tonight. Going to watch some Big Bang Theory and Mythbusters. Those two shows go good together well Quote Link to comment Share on other sites More sharing options...
Tom Posted January 13, 2012 Author Share Posted January 13, 2012 (edited) I'll give this a try and post a file, but not until later tonight. Going to watch some Big Bang Theory and Mythbusters. Those two shows go good together well Ok, but if you can, you can just say what expression I need to use, next steps I could handle myself ( I think so...) Edited January 13, 2012 by Tom Quote Link to comment Share on other sites More sharing options...
3dbeing Posted January 14, 2012 Share Posted January 14, 2012 This is a pretty cool setup. The copy chop was a bit confusing at first, and to be honest I may have done it wrong. But it should show you how to get this out of one sops chain. odforce_music_anim_3db_v1.hipnc Quote Link to comment Share on other sites More sharing options...
Tom Posted January 14, 2012 Author Share Posted January 14, 2012 Thanks 3dbeing, i will check that later. Quote Link to comment Share on other sites More sharing options...
Tom Posted January 16, 2012 Author Share Posted January 16, 2012 (edited) So I played around with your setup ( about 2 hours ), and I actualy got it to work, the way I want. Thanks guys for helping, especially 3dbeing! I will drop a result in "Final art" Edited January 16, 2012 by Tom Quote Link to comment Share on other sites More sharing options...
