Is there a include a block of VEX at compile time?
magneto
I am also trying to write some VEX code from scratch which appeals to me more actually. I am wondering if there is a function to insert a block of VEX code from a file at compile time.
So something like:
// deformer code
include "Deformer.vfl"
that will literally copy/paste the contents of the file.
Is this possible? :)
Edited by magneto
So something like:
// deformer code
Inline vop ??
http://www.sidefx.com/docs/houdini10.0/nodes/vop/inline
VEX follows C convention. From the Help:
#include "filename"
Inserts the contents of the file at this point in the source code. When you use quotes, the directory containing the current file is searched for filename before the standard locations (including the path)
