magneto Posted January 18, 2012 Share Posted January 18, 2012 You have the ability to do this for added parameters from the operator type properties dialog, but I couldn't find the equivalent option in VEX pragmas, or in the Parameter VOP. Is this supported? Would be good if I had this same ability in VEX/VOPs. Thanks Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted January 19, 2012 Share Posted January 19, 2012 For the parameter vop, the horizontally join toggle is in the third white lined section, under the invisible toggle and above the disable when string. Would like to know myself for VEXs 1 Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted January 19, 2012 Share Posted January 19, 2012 Would like to know myself for VEXs #pragma hint parameter_name hint_type The hint_type can be one of the following: ... joinnext Put the parameter after this one on the same row in the GUI. For narrow controls this can save space in the parameter editor. Example: #pragma hint myParm joinnext 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 19, 2012 Author Share Posted January 19, 2012 Thanks alot guys. I tried the joinnext pragma, but it doesn't seem to work for menus (dropdowns). Basically I have a string parameter in my VEX code and I use the choice pragma to turn it into a menu but then they are not put on the same row. I tried it with other parameters, it worked, so the pragma works but just not for menus. Anyone can repro this? Could be a bug. Thanks. Quote Link to comment Share on other sites More sharing options...
magneto Posted January 20, 2012 Author Share Posted January 20, 2012 Here is a code that shows the problem. Let me know if you can repro it, so I can submit a bug. It works when I tried the same using parameter VOPs. #define VOP_OP #define VOP_SOP #pragma opname sop1 #pragma oplabel "VEX Builder SOP" #pragma opmininputs 1 #pragma opmaxinputs 1 #pragma choice p0 "A" "A" #pragma choice p0 "B" "B" #pragma choice p0 "C" "C" #pragma choice p1 "A" "A" #pragma choice p1 "B" "B" #pragma choice p1 "C" "C" #pragma choice p2 "A" "A" #pragma choice p2 "B" "B" #pragma choice p2 "C" "C" #pragma hint p0 joinnext #pragma hint p1 joinnext sop sop1(string p0="A"; string p1="A"; string p2="A") { P.x = 0; } 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 20, 2012 Author Share Posted January 20, 2012 Also in the code I posted, if you remove the "pragma choice" lines then, it actually aligns them side by side. So it only doesn't work when they are shown as menus. Reporting as bug. Quote Link to comment Share on other sites More sharing options...
