fxjungle Posted January 20, 2012 Share Posted January 20, 2012 Maybe someone can help out on this easy thing. This is just part of a tool I am trying to build, since its for work I had to detach it from the rest, but I will use it to cookie another Geo and then take it into DOPS. I am trying to do a forEach loop where 2 sets of columns overlap and do a cookie leaving me basically a box of boxes. My problem is in my forEach, I am trying to use a second for Each inside my first one so that each cube in set A gets cookied for all the cubes in set B Since its hard to explain, I am attaching the scene. Any help is appreciated. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Macha Posted January 20, 2012 Share Posted January 20, 2012 I can't see any scene attached so I'm completely shooting in the dark and say "make sure your stamp names are different" Quote Link to comment Share on other sites More sharing options...
fxjungle Posted January 20, 2012 Author Share Posted January 20, 2012 I forgot to attach the file here it is. I know I should be using stamps, but I have to accept that my skills are still limited. cubes.hipFetching info... Quote Link to comment Share on other sites More sharing options...
fxjungle Posted January 20, 2012 Author Share Posted January 20, 2012 I should also say that although in this example I am using boxes, it will be replaced with more complex geometry that is getting generated from the same grid extrude concept. Quote Link to comment Share on other sites More sharing options...
fxjungle Posted January 21, 2012 Author Share Posted January 21, 2012 By know its only me posting here, but in case someone comes in again, here is another scene with the problem more clearly stated (I hope) Its basically doing a bunch of cookie operations in the forEach node. Thanks shatter_clean01.hipFetching info... Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted January 23, 2012 Share Posted January 23, 2012 Maybe if you could describe the effect or tool you wish to build? Also, I noticed that you aren't using the first input of the foreach sop? Quote Link to comment Share on other sites More sharing options...
fxjungle Posted January 24, 2012 Author Share Posted January 24, 2012 I disconnected the first input from the forEach as a test and it did not matter so I left it like that. Basically I want to make a Shatter Tool that works like the new splinter shatter in DMM for Maya. The concept is you have a cube that's extruded from a plane that has a pattern, be it from a texture or procedural modeling. Then put geometry that you want to shatter inside of it and Shatter it, I can do it with one cube, but if I try and add more cubes so that I can overlap them and get more interesting pieces I am getting problems. By the way, almost everything I am using I have learned it from tutorials, its this part that I am stuck because no tutorials yet cover it, but thats precisely the reason I wanna do it, I figure this way I get better at Houdini Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted January 24, 2012 Share Posted January 24, 2012 Ah, it's awesome you are checking out other packages and attempting to replicate them. Good stuff! May I suggest doing this step by step? Get the cookie sop/foreach section working first - using simple tests models to then working your way up. Make sure the primitive normals are correct, incorrect normals mess about with the results. Should be doable. For the foreach sop, I would think the individual pattern pieces need to go through the first input, and the geometry to be shattered by them in the 2nd. Hence, for each piece of the first input, create the intersection from the 2nd input. All the best! Quote Link to comment Share on other sites More sharing options...
fxjungle Posted January 25, 2012 Author Share Posted January 25, 2012 Thanks! I will have to come back to this, work get in the way. But I did get some interesting results, though not finished yet. I will clean the scene, hopefully during the weekend and post it here to share the progress. Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted January 25, 2012 Share Posted January 25, 2012 DMM in Maya is a totally different way of doing fracturing tho. If i recall correctly from some Research paper or Sketch the texture / new object sets strengths inside of the material. Then they solve a FEA system to calculate where it actually fractures. If it is just wood splinters you are after it can be faked using regular voronoi fracture tho. There should even be some tutorial somewhere if you google. Quote Link to comment Share on other sites More sharing options...
fxjungle Posted January 31, 2012 Author Share Posted January 31, 2012 On 1/25/2012 at 10:30 PM, Erik_JE said: DMM in Maya is a totally different way of doing fracturing tho. If i recall correctly from some Research paper or Sketch the texture / new object sets strengths inside of the material. Then they solve a FEA system to calculate where it actually fractures. If it is just wood splinters you are after it can be faked using regular voronoi fracture tho. There should even be some tutorial somewhere if you google. That sure sounds really interesting, but I am talking more for the way you bring in the splinter cell in DMM, that basically is a projected texture and you put your object inside that cube and it shatters in that shape. Going for different style of shapes than the voronoi fracture Quote Link to comment Share on other sites More sharing options...
