Is this the correct behavior when using $OS?
magneto
I have created a Group SOP, and then changed the name of the OP to "first", and used $OS for the group name. Later, when I change the OP name to "second", the group name stays the same, i.e. my group's name doesn't change to "second", but stays at "first".
Is it normal?
If it's, then what's the point of using $OS, as it won't reflect the most updated name of the Group SOP.
Thanks.
Is it normal?
Thanks.
If you recook the node it will be updated. I tend to use `opname(".")` instead.
  • Like 2
