use custom particle for PYRO PC Scattering?
cloudfx
Hi, is it possible to use custom particle from POP or any points for Pyro's scattering pc?
I think I saw Jeff say at one point that the pc it generates is just a bgeo anyway. I'm sure you could use any geo, so long as you have all the right attributes required.
Sounds great. :D
Do you know which attribute that I want to add to the points?
Sounds great. :D
float3 Cfire is the color of fire.
float density for smoke.
If you generate the fire and smoke .pc in pyro shader you can open them with a file SOP.
