Hello world Posted February 14, 2012 Share Posted February 14, 2012 Hi does the intersecting or overlapping geometry takes lot of time to render.is there any ways to solve this.I did a fuse SOP to reduce the point counts. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted February 14, 2012 Share Posted February 14, 2012 Hi does the intersecting or overlapping geometry takes lot of time to render.is there any ways to solve this.I did a fuse SOP to reduce the point counts. No, that alone will not increase render time. Tell us more. Are you computing GI? Are there reflections, refractions? Which renderer are you using. Quote Link to comment Share on other sites More sharing options...
Macha Posted February 15, 2012 Share Posted February 15, 2012 (edited) I think it will increase rendertime considerably. The more intersecting overlapping things you have the longer it takes for the renderer to figure out what is in front of what. If it is completely hidden I think it will just ignore the geo. At least in the viewport that's the case. But, I'm not too sure and would welcome a render-expert's opinion. Edited February 15, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
gaurav Posted February 15, 2012 Share Posted February 15, 2012 (edited) I too would like to see an explanation on this. Afaik culling of back facing micropolygons happens just before sampling the visible points in mantra. That's much later step in the pipeline, so yes having hidden/overlapping geo will increase rendertime. Edited February 15, 2012 by vectorblur Quote Link to comment Share on other sites More sharing options...
gaurav Posted February 16, 2012 Share Posted February 16, 2012 (edited) I too would like to see an explanation on this. Found it !! http://www.sidefx.com/docs/houdini11.0/rendering/rendermanypolys Last section describes occlusion culling under "Depth complexity" EDIT - Sorry guys, I should have searched the help before asking. Edited February 16, 2012 by vectorblur Quote Link to comment Share on other sites More sharing options...
