jim c Posted February 18, 2012 Share Posted February 18, 2012 Let's say I use the Copy sop to generate a variety of boxes along a series of points generated by a Scatter SOP from a grid. So in the course of this I will end up with boxes in the middle of the area which are not visible anymore and could be deleted. Is there any way in Vops (or some other node) to determine this? Quote Link to comment Share on other sites More sharing options...
moondeer Posted February 18, 2012 Share Posted February 18, 2012 SYmek suggested toNDC on another topic. converting to camera space and returning a 0-1 for line of site to the camera. maybe there is a solution here? http://www.sidefx.com/docs/houdini11.1/vex/functions/toNDC eetu even dropped a hip to check. Quote Link to comment Share on other sites More sharing options...
gaurav Posted February 18, 2012 Share Posted February 18, 2012 how about photon power. cull.hipnc Quote Link to comment Share on other sites More sharing options...
Macha Posted February 18, 2012 Share Posted February 18, 2012 (edited) You could probably draw rays from the object to the camera and see if they reach the camera first. You get a rayhit att I believe or can just transfer an attribute. If it is fast or efficient and worth the trouble, I dont know... It won't be too precise either because you have to ray from points and if you decide to scatter it could be lots. Edited February 18, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
asnowcappedromance Posted February 18, 2012 Share Posted February 18, 2012 how about photon power. that's a wicked trick, thanks for sharing that Quote Link to comment Share on other sites More sharing options...
