don't save cloud preferences
TopNub
hi
I try to run my first cloud rendering
After filling in all the settings I get the error:
An error occurred running a Python dialog callback
Traceback (most recent call last):
  File "/Library/Frameworks/Houdini.framework/Versions/11.1.118/Resources/houdini/python2.6libs/cloud.py", line 627, in <lambda>
    lambda:_onCloseSetUpCloudDialog(dialogs))
  File "/Library/Frameworks/Houdini.framework/Versions/11.1.118/Resources/houdini/python2.6libs/cloud.py", line 656, in _onCloseSetUpCloudDialog
    access_key_id, secret_access_key, _getRegionForConnectionTests())
  File "/Library/Frameworks/Houdini.framework/Versions/11.1.118/Resources/houdini/python2.6libs/cloud.py", line 121, in setAccessKeyAndGetError
    zones = connection.describe_availability_zones()
  File "/Library/Frameworks/Houdini.framework/Versions/11.1.118/Resources/houdini/python2.6libs/EC2.py", line 121, in describe_availability_zones
    return DescribeAvailabilityZonesResponse(self.make_request("DescribeAvailabilityZones", params))
  File "/Library/Frameworks/Houdini.framework/Versions/11.1.118/Resources/houdini/python2.6libs/EC2.py", line 511, in make_request
    self.connection.request("GET", "/%s" % path, data, headers)
  File "/usr/lib/python2.6/httplib.py", line 914, in request
    self._send_request(method, url, body, headers)
  File "/usr/lib/python2.6/httplib.py", line 951, in _send_request
    self.endheaders()
  File "/usr/lib/python2.6/httplib.py", line 908, in endheaders
    self._send_output()
  File "/usr/lib/python2.6/httplib.py", line 780, in _send_output
    self.send(msg)
  File "/usr/lib/python2.6/httplib.py", line 739, in send
    self.connect()
  File "/usr/lib/python2.6/httplib.py", line 1112, in connect
    sock = socket.create_connection((self.host, self.port), self.timeout)
  File "/usr/lib/python2.6/socket.py", line 561, in create_connection
    raise error, msg
error: [Errno 64] Host is down
If I understand correctly I am missing some Pythonic libraries for the cloud. Right? Where to find them? Please help.
P.S. I use Mac OS Lion
Edited by TopNub
Ok. I get it. The problem was the antivirus. :rolleyes:
But now I get this error:
OptinRequired: You are not subscribed to this service. Please go to http://aws.amazon.com to subscribe.
However, I went through all the steps in this guide http://www.sidefx.com/images/stories/news/HQueue_Cloud/hqueue_cloud_guide_09nov12.pdf , and Amazon has received $2 from my credit card.
What is the problem?
upd :)
so..., well, another dollar because the session has ended. OK, understood, understood.
I think it works, but my browser does not show me this, I do not see Process
Edited by TopNub
Maybe I'm not exactly put it.
After starting the renderer, the browser does not appear and does not show task manager.
Can you help with anything?
And how to read log file?
home-imac:Resources gilmanov$ sudo find /var/folders -name cloudsubmit.log
Password:
/var/folders/_h/77hc07t54pd2pvwnj1rcnkh80000gn/T/cloudsubmit.log
