keyframe curve + offset , chop?
cloudfx
Here is what I am trying to do.
I have 1 light with keyed intensity.
Like it starts from 0 at frame 1 and becomes 2 at frame 2 and slowly become 0 again around frame 4.
So 3 keyframes.
And I want to give a offset to this curve so I can copy paste this light to other positions and use it for other lighting in the scene.
What would be good way to work around this? chop?
So 3 keyframes.
If you want to offset the timing you can use the chf() hscript expression... so for any object you want to reference that animation you can use something like this: chf("/pathtochannel", $FF - 143) This will make the animation for this channel now start at frame 143.
That helps a lot. Thanks Solitude,
