wren output to postscript
chang
Hi, all.
I tried to open a postscript file which is rendered with wren ROP.
And it doesn't show up anything in Adobe illustrator (windows). :(
I used "wren -l 1.5 -m 1 -p -P" option.
It shows right on "md" and I think the ps file contains right amount of script data when I read it with my text viewer.
Any tip for wren usage ? Or ps-to-eps conversion?
Thanks in advance. :D
okay. the solution is,
1. nothing's wrong with wren_output_ps file.
2. problem is adobe illustrator doesn't understand level1 postscript.
3. so you have to convert the ps into eps.
4. you can do this with 'imageMagick (through ghostscript)'
