How to cut a NURBS Surface using a NURBS curve?
magneto
Thanks man, that's very close and taught me a few things. But I was actually trying to cut the pipe using a closed curve. So I changed the curve in your scene to a closed one and bypassed the extrude and it didn't work after that.
Do you know if this can be done?
Thanks man :)
Thanks man :)
Closed in what sense? As if it is revolving around the pipe or like a tube crossing the other tube? It is not really clear what you mean, can you clarify?
