Is there a way to limit the current point number to used groups?
magneto
It's hard to word this but basically I am trying to assign weights to points based on their index. So point 0 will have a value of 0, and point N will have a value of 1.
I did this no problem but when a group is specified, I want the values to be adjusted accordingly. So if you have 100 points, and then created a group for point 25-50, then I want the range to be 0-1 based on 25-50, as if 25 was 0, and 50 was 100.
Basically I need something like:
group.startIndex
group.endIndex
Can I do this purely using nodes? I am using AttribCreate so if anyone has any solutions for this, I would appreciate it.
here is the example using attributecreate and a little python as a value expression
groupName = ch("group")
geo = hou.pwd().inputs()[0].geometry()
group = geo.findPointGroup(groupName)
points = group.points()
start = points[0].number()
end = points[-1].number()
return hou.hmath.fit( lvar("PT"), start, end, 0, 1 )
look in file how it's used
weight_group.hipnc
