magneto Posted March 2, 2012 Share Posted March 2, 2012 Is there a way to bridge these 2 NURBS grid objects? I tried Bridge but AFAIK it requires profiles but I only want to use the Grid edges so not sure how to turn them into profiles. Here is the pic: Thanks Quote Link to comment Share on other sites More sharing options...
Emanuele Berti Posted March 2, 2012 Share Posted March 2, 2012 Hi Ryan, have you tried fillet SOP ? I've attached a quick example. Cheers, Emanuele fillet_twoGrids.hipnc 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 3, 2012 Author Share Posted March 3, 2012 Thanks a lot, it works great. But getting the right parameters was a little tricky Quote Link to comment Share on other sites More sharing options...
old school Posted March 3, 2012 Share Posted March 3, 2012 Some things are just better done in the viewport with interactive prompts. NURBs Fillet, Stitch and Join operations are three of these. Tab-type Fillet in the viewport then select the two or more isoparms in turn on your NURBs surfaces and all the setup is done for you. Reverse SOPs will be inserted to reverse the primitives to properly align them correctly. If you find the logic is incorrect with the interactive NURBs tools and you have a repeatable case, please submit the bug to Side Effects. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 3, 2012 Author Share Posted March 3, 2012 Old school, just tried what you said, you were right. In the viewport, it was a piece of cake. Thanks for this tip Quote Link to comment Share on other sites More sharing options...
