Any examples of using the lock expression?
I checked from the help file and tried myself but it didn't make much sense.
What's the use of this expression?
If I put in a value of 4.5 to tx, then it's as static as lock(4.5).
I thought it freezes the value at the time it's locked. For example if I use lock($F) at frame 20, then the parameter value would be locked at 20, regardless of frame change later on.
I've never seen this before.
"This function simply returns the value of its argument. However, it is special in that if an expression is enclosed in a lock function, then its values cannot be changed, until the lock expression is removed."
I'm having a hard time interpreting this description from the manual. The word "enclosed" seems to imply abstraction or bracing but not argument passing (to me at least), and then the word "its". To which is it referring? The lock functions return value or the expression that was enclosed? This dates back to H9 by the way.
The parameter field turns grey when you use it, but that's about all it does for me.
I interrupted the manual differently. So that the value returned by lock(..) can not be modified. So that lock($F)+1 on frame 20 would result in 20 and not 21.
They mean so that you can't edit the parameter in value mode.
If you want an expression that simply matches the segment's input value, use $IV.
If you want to freeze a channel (or channel range) at some particular value (at a specific frame), then you want to use the "disable" feature in the Dopesheet.
That seems useless to me, because if you have an expression like $F. You can edit the displayed value, but it won't be kept if you change frames.
Sure, but not so useless if your expression was like cubic().
