vfxstudent Posted March 7, 2012 Share Posted March 7, 2012 HI , is it possible to select at once all the edge in U or V direction of a hi poligonal mesh ? tnks a lot ! VV Quote Link to comment Share on other sites More sharing options...
Annon Posted March 7, 2012 Share Posted March 7, 2012 Please don't post questions again if no-one has answered. What exactly are you trying to do? Sounds like you want to select all edges in the u direction or v direction, but I can't work out why. Do a quick photoshop mockup and post it back so we can see what you mean. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted March 7, 2012 Share Posted March 7, 2012 (edited) is it possible to select at once all the edge in U or V direction of a hi poligonal mesh ? U and V are not directions. They are axises in the UVW coordinate system. An edge can have direction cause it's the link between two points. Working with all U coordinates to move or scale is as simple as transforming only the U component of UVWs, and the same for V. So to move all U components, then just transform it. Edited March 7, 2012 by hopbin9 Quote Link to comment Share on other sites More sharing options...
vfxstudent Posted March 7, 2012 Author Share Posted March 7, 2012 ok tnks for the help . I've posted again because maybe the category was wrong , it's more attinent to modelling I mean . As u can see I want to keep only the vertical line of this poli surface deleting the orizzontal. So I need the wireframe with only the V direction. Due to the fact that this surface is anmated even if i selected all the orizzontal loop and delete it , as soon as the animation start the geometry return in its initial state .thank a lot Quote Link to comment Share on other sites More sharing options...
zarti Posted March 9, 2012 Share Posted March 9, 2012 .. As u can see I want to keep only the vertical line of this poli surface deleting the orizzontal. So I need the wireframe with only the V direction. .. maybe this is a ' bit ' late , but here is what id do ( attached hip ).. switch inputs of the Switch1 SOP . - - selEdgez_in_U_or_V.hip .cheers 1 Quote Link to comment Share on other sites More sharing options...
vfxstudent Posted March 10, 2012 Author Share Posted March 10, 2012 It's never too late thanks Zarti !!!!!!!!! great works !!!! maybe this is a ' bit ' late , but here is what id do ( attached hip ).. switch inputs of the Switch1 SOP . - - selEdgez_in_U_or_V.hip .cheers Quote Link to comment Share on other sites More sharing options...
