hatrick Posted March 9, 2012 Share Posted March 9, 2012 (edited) i'm not shure if i get the concept wright here... Is'nt it possible to animate promoted vop parameters? ... Please see the example. Thank you L animated_vop_parameters.hip Edited March 9, 2012 by hatrick Quote Link to comment Share on other sites More sharing options...
Annon Posted March 9, 2012 Share Posted March 9, 2012 Just promote the param and then up one level you can animated the value like any other parameter... Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 9, 2012 Author Share Posted March 9, 2012 i forgot to upload the file . so it seems to be a bug .. please see above ! thank you Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted March 9, 2012 Share Posted March 9, 2012 (edited) Promote paramaters, don't create them on your VOP and don't use expressions inside VOPS to merge operators inside VOP with its UI. There is a great video about exporting parameters from VOPS here. First one explains it. cc.hip Edited March 9, 2012 by mantragora Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 9, 2012 Author Share Posted March 9, 2012 (edited) thank you! ... thought both ways should be possible... the idea came from a drag n drop workflow i ve seen around ... dragging the whole turbulence vop i.e. into the parameters interface lays down all the parameters at once ... cheers HT edit: shure there is a wrong formulation in my first post here... the parameters in my example are not! promoted thank you Edited March 9, 2012 by hatrick Quote Link to comment Share on other sites More sharing options...
