Correct way to cache a fluid simulation (or any other)??
Ankit Pruthi
Hi everyone,
Just today I was working on a flip fluid simulation and tried caching it.
These are the steps i followed:
Add a file node after gravity node, and set it to write simulation to disk, and set file compression to on.
And then, i pressed the play button and let it cache the sim in specified directory.
After this, i set it to read mode.
Now the issue i believe i am facing is that the whole DOP network is still evaluated and calculated even if i am loading the sim from disk.
So whats the correct way to load it?
I went through the help file and seems like it was the right thing to do, but this is the first time i tried caching so i am probably wrong.
Would be really helpful if someone could give a basic overview of whats the process.
Thanks for your time!!
  • 2 weeks later...
