magneto Posted March 13, 2012 Share Posted March 13, 2012 I have looked at the help but couldn't find one. Basically I have 2 NURBS surfaces bridged using the Fillet SOP, which is now a continuous surface, but I want to perform another fillet between this whole surface with another surface. So I want to reconstruct/reparameterize this surface into a single NURBS Surface. Is there a way to do this? Thanks Quote Link to comment Share on other sites More sharing options...
old school Posted March 13, 2012 Share Posted March 13, 2012 Join SOP? Quote Link to comment Share on other sites More sharing options...
magneto Posted March 13, 2012 Author Share Posted March 13, 2012 Thanks oldschool I found that to work in place of the Fillet SOP. Although I was wondering if there is a way to reparameterize a bunch of surfaces that are already connected to be a single surface. For instance in Max, you can Bridge/Blend 2 surfaces and they will be 3 surfaces total. After that you can use Join to join 2 surfaces to concatenate the CV lattices of the two original surfaces. I am not sure what it's actually called in NURBS terminology but Max's Join has 2 modes, Join (same as Houdini's Join SOP) and ZIP (the above method): More info here: http://download.autodesk.com/us/3dsmax/2012help/files/GUID-A897E9F6-42D3-495E-88DE-F16F3E09C34-736.htm Quote Link to comment Share on other sites More sharing options...
