VEX: Ramp parameter code. Spline function?
evgen
Hello.
I have the problem with using ramp parameter in vex.
What code should i use for get it works?
Seems that i need to use spline() with a few arrays of values, as in the help, but compiler gives me a lot of errors with it.
How i need to use spline function for this?
Thank you
You would have to be more specific about errors, but generally, since ramps are tedious to setup, what I usually do is that I copy code from any of SESI shaders with ramps :). ASAD light for example:
 * PROPRIETARY INFORMATION.  This software is proprietary to
#pragma ramp_rgb        atten_ramp atten_basis atten_keys atten_values
#pragma parmtag         atten_ramp rampbasisdefault linear
#pragma parmtag         atten_ramp rampshowcontrolsdefault 0
#pragma parmtag         atten_ramp rampcolortype rgb
vector
eval_ramp(float t0; string basis[]; float keys[]; vector values[])
    return spline(basis, spline("linearsolve", t0, keys), values);
string atten_basis[] = {"linear", "linear", "linear"};
float  atten_keys[] = {0.0, 0.9, 1.0};
vector atten_values[] = {{1,1,1}, {1,1,1}, {0,0,0}};
 Cl *= eval_ramp(key, atten_basis, atten_keys, atten_values);
Edited by SYmek
