Animated cookie and rbd
Tanda
Hi all, Im just a noob and just start learning Houdini about 6 months. Im doing a project which I created a simple wall and animated Cookie SOP to make some kind of crack on the wall. After that I imported it to RBD to break it. But there is weird problem that the wall's chunks appear to be missing during the animation of the crack. Im not sure it's a bug or something. I try to clean the wall geometry using Clean and try to tweak the RBD too but cant fix it. I have attached the scene file here. The scene is simple so it can be played fast.Pls help me
cookie_and_rbd.hipnc
Hi Tanda!
You should check, if possible, Houdini Tips and tricks 1st volume or so, at CmiVFX... It has a nice crack system...
If all else fails I would advise doing one thing at a time... do the crack, save out as bgeo, then break it and/in use DOPs...
best of luck!
There have been a few posts with wall cracks and debris on odforce that included example files for different ways of doing something like this. If you do a search for those threads, you might get some more ideas on how to go about this
