magneto Posted March 27, 2012 Share Posted March 27, 2012 It seems like the particle display options in the display options dialog also affect geometry points, for size. Is there a way to control them independently? I want geometry points to be bigger, but for particles I want the particles to be very small (1 pixel or so). Is there a way to do this? Thanks Quote Link to comment Share on other sites More sharing options...
malexander Posted March 28, 2012 Share Posted March 28, 2012 Not currently, no. Particles and points are both treated as points. You could try rendering particles as Discs (Geometry tab), and set that to a small value, and see if that does the trick. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 28, 2012 Author Share Posted March 28, 2012 Thanks Mark, I checked the Geometry tab but couldn't find that option. Do you mean using a Render POP? Because that has an option to render as discs, but not in the viewport I think. Also do you guys have any plans to control their display separately? Since you said "not currently", but not "not planned" Quote Link to comment Share on other sites More sharing options...
