Choudinist Posted April 10, 2012 Share Posted April 10, 2012 How can I use [creep sop] by utilizing polygon object? I want to use [polygon object] after converting it to [nurbs surface] by using [convert sop] for [creep sop], but I am having a problem when I try to apply the converted [nurbs surface] onto [creep sop]. Is there any way I can use [creep sop] by with the converted [nurbs suface] from [polygon object]? Quote Link to comment Share on other sites More sharing options...
3dbeing Posted April 10, 2012 Share Posted April 10, 2012 How can I use [creep sop] by utilizing polygon object? I want to use [polygon object] after converting it to [nurbs surface] by using [convert sop] for [creep sop], but I am having a problem when I try to apply the converted [nurbs surface] onto [creep sop]. Is there any way I can use [creep sop] by with the converted [nurbs suface] from [polygon object]? A hip file is always the best way to explain the problem you are having. Try converting your poly into a mesh. Quote Link to comment Share on other sites More sharing options...
ryew Posted April 11, 2012 Share Posted April 11, 2012 I agree with 3dbeing that providing a .hip file to demonstrate the problem you are having always makes it much easier for people to help you quicker Quote Link to comment Share on other sites More sharing options...
