How to get world coordinates at the geometry level?
I have a Geometry object and a Null object. I want to get the world coordinate position of the Null object that will always be at the position of the Null no matter the transformation of the Geometry object.
Currently I use origin expression but I get the position that's offset by the transformation of the Geometry object.
Any ideas?
in a vopnetwork, use the `optransform("path to object")` it gives you a matrix, that you can use to multiply the pointpostion to get it in global space
another thing would be (easier) use a object merge SOP and merge in the point of the null, and set it to transform into this object
this gives you the point in global space
Thanks sanostol. Do you mean using optransform in VEX? How can I use it in VOPs since you said in a vopnetwork?
I was gonna try the Object Merge, but it can be any object, i.e. very high res mesh, so that's why I didn't want to merge it just for this.
You'll need to multiply by the transform of the null and the invert transform of your geometry object. It's definitely easy enough to do in Python so that might be a better bet. You can do this with 2 of the operators I posted in your other thread connected together.
Thanks Graham, in VEX/VOPs how would you get the transform matrix of an object? I looked at VOPs just to see but didn't see anything matrix related that has an object/operator path.
I will give your operator a try for this problem as well. origin expression also works, just had to figure out the path issue there :)
