Using Width attribute of L-system in Wire Object?
masquerade
I am working on a L-system animation. I want that the tree gets affected by the forces, relatively to the width of its trunk. There is a width attribute in the wire objects physical tab, but I couldnt figure out how to use point width values of l-system tree in here. I tried using the point() expression like this:
point("/obj/LSYSTEM/NODE_WITH_WIDTH_ATTRIBUTE", $OBJID, "WIDTH",0)
but I think $OBJID refers to the objects, not the points, thats why I get the same value for all the points.
How can I assign correct width values per-point?
Thanks in advance.
Wire Object automatically takes "width" attribute from your geometry and multiplies it with Width parameter for final wire width
so if you already have "width" point/vertex attribute with correct width, just set Width parameter on Wire Object to 1 and turn on Visualization to see if that's correct
:blink:
I cant believe how I missed that.. Thank you very much. :)
