volumetric lights
melany
Hello everyone,
..I have noticed that If I create a volumetric light with a vex lit fog shader and I place a common lights in my scene i just have a white rendered frame because my common light affects the volumetric one. Therefore I have to render my volumetric light as a single pass in order to be composited aftewards with my light pass. Is there a way in Houdini for rendering volumetric lights and common lights all in the same scene, as a single pass, without affecting each other?
thank you to all suggestions B)
hank u Andrew,
do I have to write a script or do I have to set some parameters which I cannot find?!!
I mean where is the illuminance parameter, and the vector one in my lit fog shader?
I apologies for my ignorance......I am still learning :ph34r:
Fastest way to do this:
Load "VEX Lit Fog" shader.
Click right mouse button on it ---> Type Properties
Jump to VEX code tab
Add this line:
string Lightmask = "*";
after int n_octaves=3; but before ) character
Now find this line
illuminance(PP, {0, 0, 1}, M_PI)
and replace with
illuminance(PP, {0, 0, 1}, M_PI,"lightmask",Lightmask)
Push "Test Compile" button then "Accept"
Now You have Lightmask parameter.
Read drive:/HOUDINI 6.1/houdini/vex/html/shading.html#ctx_lightmask
for details.
