Rendering pyro
  • 7 months later...
its a shader compiling issue... go to your fireball shader and click 'Force Compile'. if it stil doesnt work, then click the dropdown menu next to 'Vex Compiler' and select 'VEX Compiler' and Force Compile again.. that should do the trick.
