tallkien Posted November 24, 2003 Share Posted November 24, 2003 Hey All, I'm pretty lousy at coding so please excuse, but I'm trying to create a simple render script much like the third example in the Scripting pdf My problem is I'm trying to create an outfile in the format "outfile.$F4.ext" which works fine except the frame numbers don't update each frame. I get outfile.0001.pic but subsequent frames just overwrite the first image. I could use fcur and get the frame number but how do I pad it then? Any help appreciated Thanks Quote Link to comment Share on other sites More sharing options...
deecue Posted November 25, 2003 Share Posted November 25, 2003 did you try it without the period? i.e. "outfile$F4.ext" haven't tested to see if that's it or not (i would think it should be fine with the period tho), but you could try that. if it works without the period. render it like that and if you really wanted the period in there, you could insert it with a mass file renamer. i suggest Albert Bertilsson's Renamer. It's is definately a nice prog... http://www.albert.nu/common.asp?sub=progra...enamer/main.htm other attempt i would try is "outfile.`$F4`.ext" since most scripts are put in ticks. hope something works like that. when i get a moment, ill test them out as well. dave Quote Link to comment Share on other sites More sharing options...
tallkien Posted November 25, 2003 Author Share Posted November 25, 2003 edward pointed me to the existing hrender script and it works just fine for what i need. I'm able to supply outFile in any format I want :- outfile_\$F3.foo, outfile.\$F4.foo, etc my file's source is here , If you do spot something please do let me know I have two procs on my machine so I thought why not keep the other busy while I work. Although Apprentice allows two parallel sessions I wanted to avoid the overhead of the second gui Thanks Quote Link to comment Share on other sites More sharing options...
