glass rendering slower [ SOLVED ]
hi everyone ,
im in a situation where i have prepared to export buffers of a glass material separately to later have maximum control in compositing process .. i did this also in order to spare as much time as possible in rendering . ( Micropoly , H11, b.1.229, WIN7_x64 )
what i cant explain is the fact that the first frame starts and render in very acceptable times for me , while any other frame but the first one renders many .. but Many times slower . indeed it starts so slow that i accidentally discovered it was rendering( had a phone call =) ) . when i came back i noticed the first completed buckets ( ! ) .
i believe there is nothing changing between frames in shading context and im simply rotating the object just to see its appearance under different POVs .
based on your experience( if you had one like this ), what could be causing this ??
any help or hint wd be greatly appreciated .
!thanks
EDIT ::
the original name of this topic was "render slower on frames different from 1 ( ?? )" .
i updated it in order to make more sense , more 'visible' and maybe help quickly someone in future ..
sorry .. and hope this editing isnt breaking any rule =)
Edited by zarti
i just found what was it .. > Many overlaping primitives . not so many .. =)
shame on me , but i can justify my self a bit by saying that the geometry was modeled and exported from a NURBS modelling app .
also , its polycount was high , so i didnt suspected at that .
also the orientation of faces towards the camera where rays were bouncing was minimal on the first frame . hence the fast rendering of it .
to be fair toward the First Frame and thank it =) that helped rising my doubts a lot and posting this topic .
the comparison wdnt be possible without you , first Frame , and electricity bill will be lighter this month .. =)
anyway im trying to make this topic( maybe )useful for someone else in the days to come :
if you suspect sometimes that Glass is rendering ' more than what you wd expect ' .. throw a Clean SOP and see what it cleans .
also be careful with Foreach SOPs( when you arent creating extra geometry within those )by comparing the quantity of geometry coming in and out from those .
in my case i didnt investigated up the nodal flow on Foreach SOPs i used to elaborate that model , but just a warning .. ;)
thank you Michael for your reply !
Edited by zarti
