Converting point selection to polygon selection
in the group node in the edit tab , you can convert point to primitive group , for the second question , i don't really understood what you mean
Edited by sly
Thansk for answer for 1st question!
Well, if I extruded some selected polygons and deselected them, how can i reselect same selection?
Edited by ioscat
Ioscat, I believe you are still thinking along the lines of maya, where you select some faces, hit extrude, select some other faces, hit extrude etc...
Houdini isn't really like that, you make groups with expressions or however you want, then use those groups to control what another node does, in your case polyExtrude. Middle click on the node and you can see what groups they contain, that's how you "reselect" them.
