lynbo Posted May 22, 2012 Share Posted May 22, 2012 I have a character that I have setup using the autorig tools. It seems to have added some Cd or UV attributes that are rendering instead of my chosen materials. I get my last viewed Infa-red capture weight painting colors applied to my character. What have I done wrong?! any ideas? keep in mind this ( character rigging ) is not my field of speciality. If I could have someone else do it I would. Just gotta power through. Thanks posted this on SESI Forum as well. Quote Link to comment Share on other sites More sharing options...
edward Posted May 22, 2012 Share Posted May 22, 2012 Find the skin object which contains your geometry. Make sure that the Capture SOP in there has Visualize attributes(?) turned off. Quote Link to comment Share on other sites More sharing options...
lynbo Posted May 22, 2012 Author Share Posted May 22, 2012 Find the skin object which contains your geometry. Make sure that the Capture SOP in there has Visualize attributes(?) turned off. Excellent, not quite it but it put me on the right track, I turned off the visualize attr, and also later in the graph on in the deform node I checked delete point colors, and that seems to have worked, thanks a ton. Quote Link to comment Share on other sites More sharing options...
