Omy Posted May 30, 2012 Share Posted May 30, 2012 hi I am trying to advect density.but only it advects in the first frame after that it stops. I turned on set always.dont know where i went wrong.could any one look at my file please.thank u doubt1_densityadvevction.hipnc Quote Link to comment Share on other sites More sharing options...
old school Posted May 30, 2012 Share Posted May 30, 2012 You can add density to the Field parameter in the first Gas Advect VOP and bypass the Gas Advect Field VOP if you wish. That works and both get the same advection rate. Or just create another Gas Advect VOP with a different advection rate and that works as well. If you want to keep the network the way it is and use the advanced MacCormack or BFECC advection methods, you need to enable the "Allow Self-Advection" parameter. This will force the creation of additional fields required to do the advanced advection methods. If you were to use a Smoke Object in place of the Empty DOP object, but I digress... Quote Link to comment Share on other sites More sharing options...
Omy Posted June 8, 2012 Author Share Posted June 8, 2012 could you share the file. I cant understand fully and I dont know where the self advection parameter is I have followed the jeff lait video Quote Link to comment Share on other sites More sharing options...
sadhu Posted June 8, 2012 Share Posted June 8, 2012 Set the default operation on sop scalar field to set initial and it will start advecting density. Quote Link to comment Share on other sites More sharing options...
