jim c Posted June 3, 2012 Share Posted June 3, 2012 (edited) In the Channel editor in H12, I can't grab the curve and manipulate the handles. It used to be that I could do this and change the curve, move the keyframe around, etc. No more. Is there some obscure setting that I need to enable to do this? Anyone else have a problem with this? Edited June 3, 2012 by jim c Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted June 3, 2012 Share Posted June 3, 2012 (edited) Do you see them ? If not maybe you got View->ShowHandles set to "None" Edited June 3, 2012 by mantragora Quote Link to comment Share on other sites More sharing options...
jim c Posted June 3, 2012 Author Share Posted June 3, 2012 No, it's weird, I can see them, and if I click drag, I can select the *curve*, or select the bezier control handles, but I can't click on the handles themselves - they just disappear the moment I do. I can't change the position in the graph with the mouse itself. I can change the numerical values in the edit boxes. Quote Link to comment Share on other sites More sharing options...
jim c Posted June 4, 2012 Author Share Posted June 4, 2012 Sigh. So I closed H12. Again. Started up H10, fiddled with some curves there, worked fine. Closed it, and then restarted H12. Now the curves work. WTF??!?! Is there any reason for this? Do the gods of animation just hate my guts? Did not properly sacrifice a virgin? Am I missing a unicorn, or perhaps the blood of a newt? Unicorns and virgins are tough to come by in NYC, but I'm pretty sure the girl beneath us cooks with the blood of a newt... Quote Link to comment Share on other sites More sharing options...
edward Posted June 4, 2012 Share Posted June 4, 2012 Those symptoms sounds like the OpenGL state is screwed up. Is it with particular channels? Quote Link to comment Share on other sites More sharing options...
jim c Posted June 4, 2012 Author Share Posted June 4, 2012 No, it appeared to be any channel. I tried creating a little bouncing ball animation, and reproduced the problem on all the motion channels. Quote Link to comment Share on other sites More sharing options...
edward Posted June 5, 2012 Share Posted June 5, 2012 Sounds like a restart fixes it though If you can narrow it down to a set of specific actions to reproduce, please log it. PS. You're not on an ATI/AMD video card? Quote Link to comment Share on other sites More sharing options...
jim c Posted June 5, 2012 Author Share Posted June 5, 2012 Nope, Nvidia Quadro 4000, bought just for Houdini Unfortunately I don't know what to do to reproduce. I have noticed a couple of other 3D viewport issues, like sometimes the display goes all black (say when I switch from the Render View back to the Scene View). If I switch the Display Mode from Open GL 3.2 to H11, then it returns to normal. On a side note, I have to say, since I've been using Houdini since 2008, this has been the buggiest release I've used. While I really appreciate all the hard work that went into various things, as a user it's been a really frustrating experience. The render improvements are great, but the weird display issues and odd crashes are extremely frustrating. Luckily each release seems to get a bit more stable, so that good! (apologies for ranting). Quote Link to comment Share on other sites More sharing options...
