Applying shader / texture to small area of object
Hi all,
I am wondering how I can map a graphic i create in photoshop onto an area of my model. I want to put a face on a lego man but want to apply it to a small square section on the rounded head (i.e. select a small surface area from the whole area).
When I have tried before it still applies it to the whole of the head as opposed to the small section.
Any help would be greatly appreciated
Trappy :ph34r:
There are several ways, as always with H.
First you can apply a UVproject SOP and size it to the area you like, or you could create a group SOP with the area you want the shader to be in and apply a UVtexture SOP to the group and a different UVtexture to the rest of the model.
