Pose state
betty
hi all,
I'm just going over the tutorials for character setup and one thing mentioned is the "POSE" state.
I'm a little confused as they mention you have to be at frame 0 to be able to pose your model.
Can you do this? - pose your model in various ways and save those poses. then go to any frame you like and bring up a "pose" and keyframe at that spot. this is what i thought the pose state would be used for, but it's got me all confused!!
any words of wisdom?
Hi Betty,
Are you talking about the "capture frame"? I guess one of the best example I can think of is, if you don't keyframe the "capture frame" state, which can be at any frame number; you then save your file after you pose your character and reloaded it. You'll see that you your skeleton will pop back into the original unposed position while your model stayed at teh last pose. I believe this is because Houdini recooked the capture.
As for the "Pose" at the top Object's Viewport, aren't these just for the ease of selecting the end affector of a bone or something? It's just look like it that way...
Any way, I am still learning about the "why" on these as well. So... I could be totally wrong...
Anyone?
heh. Guess I was late. :D
