cloudfx Posted June 6, 2012 Share Posted June 6, 2012 (edited) Made a little box container and trying to use that as rigid body static solver. My fluid flip is not colliding with this. Set-up seems right but dont know what I am missing. sim_liquid_v04.hip Edited June 6, 2012 by cloudfx Quote Link to comment Share on other sites More sharing options...
sadhu Posted June 7, 2012 Share Posted June 7, 2012 Just check the collision guide geometry of the static object. Increase the thickness of your container walls and increase the uniform division on static object<collisions<volume Quote Link to comment Share on other sites More sharing options...
Filipp Elizarov Posted June 7, 2012 Share Posted June 7, 2012 1.Lets dive inside Static object and turn off display geometry (you will see nothing) 2.Go to Collision tab - Volume - turn on Show collision guide geometry 3.Turn on laser scan 4.Increase uniform devision from 30 to 100 or a bit more. Will be perfect. Keep in mind when you are working with collision geometry always try to check it with Show collision guide geometry (Because usually your geometry from SOP doesn't looks like same after convering it to a volume in dop network) Quote Link to comment Share on other sites More sharing options...
Filipp Elizarov Posted June 7, 2012 Share Posted June 7, 2012 (edited) here is a screenshot. Edited June 7, 2012 by Filipp Elizarov 1 Quote Link to comment Share on other sites More sharing options...
Filipp Elizarov Posted June 7, 2012 Share Posted June 7, 2012 (edited) But i think your problem not only in bad collision geometry. Go to Source volume in DOP - Volume operation - and change your Source Volume (from COPY to ADD) Think it will help. Edited June 7, 2012 by Filipp Elizarov Quote Link to comment Share on other sites More sharing options...
