muzaffer Posted July 3, 2012 Share Posted July 3, 2012 Hello, I am playing RBD object node, in this node create active Object option, trying to make an object moving with another one, after some frames i want to activate create active object option, to sim separately, Thanks for the Answer Quote Link to comment Share on other sites More sharing options...
stephenl Posted July 6, 2012 Share Posted July 6, 2012 If I understand your question, use the active value node or modify value node. Active value is simpler it is a basically a preset of the modify value node. If you want to change other values other than activation you need to use modify value node and use details view to find the name and info. Quote Link to comment Share on other sites More sharing options...
